Dyess AFB Trunked gone silent
fasteddy64
Gulfport, MS
Good deal 😊 Appears same info as listed on rrdb. Try to search in the 380 freqs see the voice channels are the same.
I tried.
I am hearing activity but nothing I can decode.
Perhaps they have changed the control channel and gone encrypted?
nd5y
Wichita Falls, TX
Unless they encrypted everything or you have some programming problem where your scanner isn't tracking the system properly it appears that all they did was rotate the control channel.
Try making a conventional system with all 10 frequencies in the database set to auto mode with no tone or NAC where it will receive everything digital or analog. If there is a setting that mutes encrypted audio turn it off. You will have to lock out the active control channel. Then see if you hear anything. Maybe it's just dead because of a holiday weekend.
If you don't hear anything but see lots of short transmissions then that could be OTAR or other data.
It's going to take somebody with Unitrunker or Pro96Com to figure out exactly what is going on.
fasteddy64
Gulfport, MS
So I made another system, just put in the active control channel and I am now getting traffic. Multiple talk groups active this afternoon. The old system is still silent.
scanaholic
Abilene, TX.
Awesome! Glad to hear that, Ed. I wouldn't begin to know how to do all that on my old PSR 600. Probably couldn't be done. That's not a huge problem, as I would usually lock Dyess out anyway when I turned it on. :)
