In my mind from a long time ago I recall seeing many turns of fine enamel wire on a #75 mix, 2.4" toroid ring.
The ring was wound almost full of fine enameled wire, say #30.
The COLD or bottom of that winding was for common or reference.
The top end had a piece of PC board or wire of a few feet going vertical.
Around the bottom of the winding were several turns of coupling loop which terminated in coax. RG58/6.
The bottom of the large inductor and the cold side of the coupling loop were tied together as common.
The inner of the coax was tied to the other side of the pick up loop.
The antenna was hoisted vertically, say to 50' above ground with RG58/6 coax feed to see common mode decoupling, thence to the shack..
Any bells??
Dave/W1FRV
Any bells??
Dave/W1FRV
