TRX-2: E - Z Scan
Mojaveflyer
Denver, Co
I've loaded a number of frequencies in to my TRX-2 for a road trip to California. When I go to 'Conventional Frequencies', it only shows up Bank 20, even though I have up to Scan List 70 loaded. In the list for LAPD, they use a conventional system but with P-25 modulation. I can't seem to modify what's loaded since I can't seem to get above Scan List 20. Any ideas?
TES
America's High Plains
Sounds to me like you're confusing Scan Sets for Scanlists.
Mojaveflyer
Denver, Co
TRX-1 Programming
Under 'Advanced Features' I'm not seeing the display tabs you mention.
Advanced -> Show Conventional Frequencies Tab
Advanced -> Show Trunk Systems Tab
I see the 'Conventional Frequencies' and 'Show Trunk Systems' tab across the top but it still only shows the 1st 20 groups I have loaded.
Wackyracer
I recommend you use Vscanners folders for out of town trips, this will keep your home area frequencies and scanner settings separated from the other areas and can switch back easy to you home area.
troymail
Silent Key
Advanced MENU option above that....
