how to fix a ear jack / 106
In this picture you see a ear jack for a PRO 106, to fix it to make it work when you plug a 3.5 mm plug,
this is what you do.
# 1 take the back casing off the radio ( remove the 4 screws that hold in on )
# 2 turn the radio up side down & look where the ear jack is.
# 3 take a paper clip & open one end of it & use it to PUSH that copper arm back in the hole some, NOT to far.
# 4 if you need to LOOK at the picture of the ear jack that is attached.
# 5 reassemble the back, & retry the ear jack, it should work.
