Earthquake warning/monitoring frequencies
foggya
Foggya, where are you living? Are in a quake prone area. I wouldn't worry too much about Tsunamis unless you are close to a body of water: ocean or even lake. There have been instances of LARGE landslides into lake and create a tsunami, bun infrequent.
I just moved to SoCal and right away experienced a pretty decent earthquake for starters,
I was staying in Palmdale and found out that i am right in tbe epicenter of the largest earthquake in CA some 200 years ago. A friend showed me the massive marks it left, and the infamous San Andreas fault.
You can really see it pretty much everywhere you step.
For work I have to commute to LA few miles from the beach where I saw some signs for Tsunami evacuations, I know they have sirens right at the beach but I am a little too far to hear them.
By the way, what is the purpose of those ads from Earthquake authority, I see them all the time on TV, radio...
So goes my good night sleep:)
foggya
Having lived in California most of my life, I've been through a number of large earthquakes.
While they can travel quite a ways, it's on the order of a few seconds at most. I've been on the phone with people or listening to AM radios stations and will hear someone say "I think that was an earthquake" about the same time I feel it.
True. There are many small earthquakes every day, but they are not felt, do no damage and don't warrant making the news. Unless it is a "swarm" of earthquakes, they don't talk about them.
The delay is due to the processing of the information. A seismograph will tell you there was an earthquake and how strong it was at that station. What the USGS does is to take data from many seismographs and plot the epicenter and magnitude. That takes some time.
You won't hear earthquake warnings. I have heard tsunami warnings, though.
Predicting earthquakes isn't something that has been perfected yet, so no government agency is going to announce predictions.
Many researchers are working on ways to do this, and have been for decades, but it's still in the research phase. The issue is that earthquakes large enough to provide useful information are not common enough or frequent enough to provide enough data.
Many years ago we had a site that had a remote earthquake sensor. We supported the network connection for it. The data was being fed back to a university in Germany.
I'm currently involved in getting a few connections to remote seismographs for a research project UC Berkeley is doing along the same lines. The connections are all IP based, so nothing you can monitor with a radio.
I do have another site that has a USGS seismograph being fed back via a phone line. Having had to repair the line a few times, I can tell you that it's just a steady audio tone that supposedly changes pitch when the sensor vibrates. Luckily/unfortunately I've never been clipped on the line when there was an earthquake…
So, earthquake predictions are not an exact science, yet. But it's being worked on.
Best thing you can do is be prepared at all times, and hang on when it does happen.
Thanks for clarifying, I was under the impression that the san andreas fault in particular is so long that the earthquake could travel for a few seconds to minutes before it reaches my place.
I saw an app from UC Berkeley, called MyShake, is that one you are working on? that is a pretty cool project. I think the whole purpose of that project is to warn facilities to disengage ith sensitive equipment and prevent more damage, e.g. nuclear power plants etc...
unfortunately my internet connection is very spotty and unreliable.
Thanks for your hard work :)
No, not that I'm aware of.
This is a network of sensors spread across the state and fed via IP back to them. I'm only involved in two of the sites that are on land we manage.
foggya
Holly... I think Indonesia got like 3 dozens of aftershocks in the past day.
ShawnInPaso
Hey Foggya -
Have you looked at the NWS Weather Radio Codes?
They do have earthquake warnings broadcasts, in reality that probably means it has already occurred and you have to have the receiver programmed to the county(ies) which is affected by the quake.
NOAA Weather Radio - EAS Event Codes
Have a look at this Midland WX receiver. It's inexpensive and has a lot of features, including an aux jack which can be used to enable a transmitter (for example, a repeater IAW part 97 rules).
https://www.amazon.com/gp/product/B00176T9OY/ref=ox_sc_act_title_1?smid=ATVPDKIKX0DER&psc=1
