Specs below. Lots of copy & paste options!
ARC-XT supports the following scanner models: BCD396XT , BC346XT(C) , BCD996XT and BCT15X.
ARC-XT includes the most versatile and most feature rich editor available on the market.
ARC-XT combines the best of 2 worlds! With ARC-XT you can directly access (*) the RadioReference.com Database and import over 9000(!) trunk and conventional systems directly into your scanner!
QuickKey Overview: 'Drag and Drop' your systems/sites or groups in QuickKeys.
Built in lookup utility to find Latitude & Longitude based on US address or zipcode
ARC XT can import ARC246/ARC996/ARC396/ARC15 system files.
ARC-XT is fully compatible with the new Radioreference webservice.
Built in decimal <> hexadecimal converter
Bandplan Editor: change the default step and mode settings per band. Also included are 3 European preset bandplans.
Handy tools menu
Copy/paste groups between systems, building new systems was never this easy!
Read data directly from the RadioReference Database, 'browse' for local trunk systems and let ARC-XT do the programming!
'intelli upload': Replaces systems that are stored in your scanner without having to reset your scanner first! ARC-XT will never reset your scanner!
ARC-XT-PRO also includes full PC Virtual Control and a very enhanced recorder with 'no loss' digital recording technology and data logging.
ARC-XT-PRO Intelligent Data Storage recorder: wav files are automatically stored in folders based on system/group/date/time.
ARC-XT-PRO wav files are stored per frequency or talkgroup for easy playback.
ARC-XT-PRO includes a fantastic bandscope option.
ARC-XT-PRO includes a Tone Out frequency logger.
Don't have a serial port? ARC-XT also works with the Uniden USB-1 cable.
ARC-XT supports the following Uniden scanner models: BC346XT(C), BCD396XT, BCD996XT and the BCT15X.
Handy tools menu
