Easiest (and cost effective) way to stream multiple feeds to RDIO
dannews
Sydney, Australia
Hi there,
I'm wanting to stream multiple different audio feeds of ATC. What's the best way to feed them all? Happy to learn how to set up Raspberry Pi or similar if needed (unless someone knows of a guide?)
There would be about 5 or so. I'm a newbie when it comes to the streaming side of things but am keen to learn.
rdmcvicar
Middleton, (Dane County) WI
I mainly use rtlsdr_airband to create files, which a rdio-scanner instance on the same machine ingests via dirwatch and then downstreams to a main rdio-scanner server. If all the ingest was at the same location (mine aren't), the rdio-scanner instance alongside rtlsdr_airband could possibly be a server. All my rdio-scanner stuff is just for private streaming and easy playback, with each receiver also sending to LiveATC.
I played very briefly with a fork of rtlsdr_airband that directly sent to rdio-scanner without the need for a local instance, but couldn't quickly get it working for what I needed and haven't tried it in a while.
(Anyone reading this and coming to Oshkosh, Wisconsin, USA next week for EAA AirVenture 2025, please feel free to DM and say hi.)
