Hello i have a UNIDEN BCD 325PS SCANNER I LIVE CANTON TEXAS I HEAR EAST OF CANTON NOT WEST OF CANTON WHAT UP WITH THAT?
Which Kaufman County system do you have programmed?I CAN NOT HEAR KAUFMEN COUNTY AT ALL BUT SMITH COUNTY I CAN HEAR LINDALE SOME TYLER PD AND FIRE AND I HEAR VAN ZANDT COUNTY AM USEING P25PHASEII
I'm farther away, west-northwest, from Kaufman than the OP, but I get good reception.Canton TX appears to be on the fringes of the reception range for Kaufman County. The Kaufman system is also Simulcast, which may pose a problem for reception if you are equidistant to multiple transmitters.
The current trunked system phaseIIWhich Kaufman County system do you have programmed?
The old Vhf conventional channels?
Or the current trunked system?
Are you using the scanner's original antenna, or a different one? If different, which one?
original antennaThe current trunked system phaseII
What model of scanner are you using compared to the OP? Internal or external antenna? You actually may have better reception on the Simulcast system due to your greater distance. Simulcast distortion problems seem to be inconsistent, and based on a number of variables which make diagnosing the resulting reception problems difficult at best.I'm farther away, west-northwest, from Kaufman than the OP, but I get good reception.
Hold on the Kaufman system, and look at the display.original antenna
I have multiple scanners that can receive the system. A 325P2 (with the Remtronix 800MHz antenna), two 436HPs )Remtronix also), SDS100 (the SDS100 version of the Remtronix), and SDS200 (back of set antenna). These are inside a house with aluminum siding, which hinders reception in some cases.What model of scanner are you using compared to the OP? Internal or external antenna? You actually may have better reception on the Simulcast system due to your greater distance. Simulcast distortion problems seem to be inconsistent, and based on a number of variables which make diagnosing the resulting reception problems difficult at best.
no signal strength at allHold on the Kaufman system, and look at the display.
Are you seeing any bars in the upper right corner, indicating signal strength?
OK, you may be out of range then. You might look at this antenna:no signal strength at all
Tell me about it! I've been dealing with that demon for many years when using portables in the house. While I have an external discone, that proves to be too much signal for my local 800 MHz Simulcast systems I monitor.These are inside a house with aluminum siding, which hinders reception in some cases.
Are you seeing any signal strength indication on your 325P2 with the Remtronix antenna? Or is the scanner showing "finding control channel" when you hold on the Kaufman system?no signal strength at all
