Blue background
ScannaMan9
That is one of the alert colors (cyan) you can set for a transmission. It stays on for a few seconds and then turns off. There are 6 other colors you can use also. I took the picture during a transmission on both 996's. The upper one I use for recording, but both are programmed the same. I only listen to the lower 996. The laptop is the recorder.
Stephen
