EDACS alternate control channel
Jammin_Jay
On an EDACS system. Can anyone of the channels in the trunking system, be an alternate control channel ?
I noticed on the ottawa EDACS that the c.c. has changed, numerous times, but was not listed on RR as one of the alternates.
rchalupajr
I listen ta an Edacs system in my area. It has 6 frequencies, 5 of the 6 have been used as a control channel at one time or another
rdale
Lansing, MI
It doesn't really matter for EDACS systems because you enter all LCN's the same, no matter if they are a CC or not.
Thayne
Any EDACS LCN can be a control channel, and the controller will do it automatically if need be.
I heard somwhere that MOTO CC's have to be set up in advance and can only be 3 or 4 Max.
Some have said that EDACS trunking is actually more failsafe than MOTO but I don't know the reasoning behind it--
DaveH
Ottawa, Ont.
On Site 1, 12 of 15 channels have been heard as CCs going back over at least
a few years. I suspect any LCN can be a CC, but it's kind of academic as EDACS
doesn't work with CC-only mode.
Dave
IdleMonitor
The Ottawa Valley - Eastern Ontario
I've listened to the Ottawa system with Control Channel only mode. It does work. As long as you have all the correct Ctrl. Ch's in your radio
Dave
rdale
Lansing, MI
Absolutely wrong... You can't even program an EDACS system as control channel only mode.
IdleMonitor
Ok ;) But I know how I programmed the radio and I know what I've heard and seen. And you can program it with control channel only.
Currently I have 5 ctrl ch. in site 007 at the moment, and i've had no problems with it.
0866.1375 1
0866.3875 2
0866.6375 3
0867.3875 4
0867.8875 5
DaveH
Ottawa, Ont.
Probably the reason it works is that you still have all the LCNs programmed in,
and you may think the radio is in CC-only mode but it is not.
Try removing all LCNs except the current control channel, and see if it
still works, and let us know.
Dave
Jammin_Jay
I never thought you could program an EDACS as CC only mode. If you have 5 of the alternates programmed in, then each one of those 5 is an LCN. I just wondered because if someone was to come across an unknown EDACS site, somwhere else then Ottawa, and all the frequencies in logical order was not available to them, then its not possible to extract them from a CC only mode. Also out of curiousity, is an EDACS site expandable to add more frequencies as LCN's to the ones that already exist, if radio traffic warrants it. I understand that it can take up to 24 channels max.
rdale
Lansing, MI
You cannot program CC-only for EDACS.
Yes, they can be expanded.
exkalibur
York, Ontario
They can be expanded, however adding a single LCN means *every* system radio will need to be re-programmed, so this isn't done very often.
And no, CC only is impossible on an EDACS system.
davidmc36
South East Ontario
0866.1375 1
0866.3875 2
0866.6375 3
0867.3875 4
0867.8875 5
If those are the only frequencies that you have in that system then you are missing parts of converstaions, you just don't realize it. You need all ten programmed in and in the right order.
DaveH
Ottawa, Ont.
0866.1375 1
0866.3875 2
0866.6375 3
0867.3875 4
0867.8875 5
With this setup you'll be receiving about 4/9 of the total traffic:
- for messages carried by only the four voice LCNs programmed, operation
would appear "normal".
-for messages carried on the five voice LCNs not programmed, you'll hear
nothing, which may seem "normal" but you'll be none the wiser, unless you
were scanning all voice channels on another scanner (not a bad test),
or trunking with all LCNs programmed.
-for messages carried by a mix of LCNs, you should hear fragmented
conversations. Listen carefully, that is your clue.
Dave
IdleMonitor
Well, I'll try this next time I'm in Ottawa. Haven't been able to hear OFD from my location since getting the 396T due to sensitivity of the radio so...
I just figured since it was a radio that did Ctrl. Ch. only scanning that everything was working properly.
Always learning something new.
Dave
