EDACS Conventional Priority Scan
TDR-94
Why then does RPM require Enhanced CC scan to be selected in order to select a conventional priority for use with a P25T system.With a P25T system selected there is no other way to select a conventional priority for ECPS1 other than using Enhanced CC scan.Seems like ECPS1 was never 'actually' made functional with any P25T system.I've seen it work fine in conjunction with EDACS.
TDR-94
Found out that the P7100 doesn't support P25T Conventional Priority Scan together.Only EDACS ECPS1.The P7200 and newer radios support both EDACS and P25T ECPS1.
