I have seen many references to ESK for EDACS. What is that?
Lovely.chrisjz said:.. M/A-COM is working on a DES encrypted version that would require the use of a DES key which can not be cracked easily and would render trunk trackers useless once again.
Security is a crucial feature of any critical communications system as any security breach on a system compromises its effectiveness and that of the public safety professionals that rely on it. EDACS Security Key (ESK) addresses this need through several unique features:
• ESK allows each customer to define a unique security code that is programmed into the radio products and site equipment. During normal operation, if the code stored in the radio and site do not match, the radio will not receive calls from or transmit calls to that particular site
• ESK prevents trunked radio scanners from monitoring radio traffic on an EDACS site
• ESK offers restricted access to radio programming. Once a radio has been programmed with an ESK security code, that radio cannot be read or altered unless the specific code is provided by the user.
scanner_freak said:From M/A COM's Web Site about ESK:
http://www.macom-wireless.com/news/pressdetail.asp?id=35
Seems to me there are deliberately going after scanner users..
N_Jay said:There is no advantage to having the system open (except to the people here)
UPMan said:There is no advantage to having the system open (except to the people here)
Add to the "people here":
While all of these groups can theoretically be equipped with either personal HT's or with transmit disabled HT's, the cost delta between a scanner and an HT is usually on the order of 500-1000%.
- Off-duty first responders
Neighboring community public safety (as adjunct to two-way radios, where only monitoring is needed)
Media
Auxiliary "secondary" responders such as RACES, Red Cross, etc
marcp90 said:I have seen many references to ESK for EDACS. What is that?
chrisjz said:In other words, it's a band-aid for a flaw in EDACS.
I think describing ESK in this fashion is completely wrong. There were before ESK and still are several ways to have many distant EDACS systems operate together without interfering with each other. The main way to do it is to "color" the system. You can assign a color in the programming of an EDACS system and radios to separate two systems with common frequencies. For example, if 2 systems have a common control channel, you can have system A be black and system B be green. Radios from the green system will never see the black and vice versa. ESK is exactly what it was designed and being re-designed to DES for, to keep scanner listeners and unauthorized radios (EBAY radios, etc.) out.
blantonl said:Uh huh... sure.
Tell that to San Antonio and Corpus Christi...
chrisjz said:There were before ESK and still are several ways to have many distant EDACS systems operate together without interfering with each other.
Com-4 said:"ESK is not needed to keep scanners out, ProVoice does the job just fine."
True, but we all know if there is a ProVoice system in the area that is NOT ESK, we run to buy the software thru M/A Com,buy a ProVoice radio on ebay, and there we go. Legal, and very easy. ESK prevents that from occuring. Rather or not this was M/A Coms REAL intention is unknown since you really cant beleive what a M/A Com salesman is saying to be true,all he wants is to make the sale. Only the inventor knows its true purpose.
