EDACS Group names transferable to P25 Groupset?
TDR-94
I'm guessing there is no way to transfer/copy EDACS group names over to a P25 groupset,so they don't have to be entered from scratch all over again,correct?
Radioman96p71
Nope, no simple way. Have to start from scratch again.
TDR-94
Does LCN order still apply with Harris P25 systems and do those systems still use transmission trunking?
DisasterGuy
Maryland Shore
Not sure why you would want to move the sets as the parameters change. P25 group sets get populated with multi group settings, sys ID settings etc that are not part of EDACS sets (assuming a system were to migrate with no change in GIDs).
While it is some work, so is fleet mapping in general. I am in the middle up forming our master personality under scratch build revision 3 right now. It comes with the job for system cutover.
As for trunking mode, either message or transmission trunking is available via UAS config.
Sent from my SM-G900V using Tapatalk
TDR-94
The group names would remain the same as they currently are on the EDACS system.Coping just those over to the P25 group name settings would have been a real time saver.
