EDACS I-Calls - Filtering?
HowD
Ozaukee County, WI
Hello.
Is there a way to set up the PSR-500 to allow only a certain block of radio IDs for I-Calls, short of entering each one as a separate PC object?
For instance, let's say the users of the I-Call have radios numbered anywhere from 1 through 10000 (decimal). Can I limit the PC wildcard group to only radios 6000-6999? Is there a way to put 6**** in there similar to the way the Weather SAME codes work with just the first digits and the rest asterisks?
HowD
Ozaukee County, WI
Thanks, Wayne, for the quick reply and concise answer.
I did have an idea to help decrease the number of entries that would be required....Use logging over a period of time to see what radio IDs are in use on a regular basis. The problem, of course, is if a radio is used that wasn't on the list made from monitoring.
Or, perhaps, if certain units (that I don't want to hear) tend to chit-chat, can I put those in as a PC and then lock them out...I'll think give that one a try.
'Tis good to think aloud (akeyboard?) sometimes...
