EDACS INFO
toddballew
toddballew
Pro 95 Scanner, software BC250 Butel, is Volusia County use Eadcs wide or narrow edacs, should id qactivity be on, should emergency atl be on, anyone know, please help
edweirdFL
Daytona Beach, FL
When the RR DB listing for an EDACS system says
System Type: EDACS Networked Standard
you should use the wide setting.
Ed
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
Pro-95 and ARC250 are not compatible.
If Win95 is your software, it does not have ID Activity nor Emergency Alt, because the scanner doesn't use those features (the scanner ignorse empty ID's).
If the BC250D or 296D is your scanner, I don't have either of those items checked in my local EDACS Wide system using a BC785D
ID Activity: If this option is selected, ARC250/785 will delete 'empty' trunk id's.
Emergency Alternate: I can't help with because not in the help section.
Also, each site must be set in seperate banks in correct LCN starting with channel 01.
