EDACS LCN Order
mikebennett
Sherman, TX
I am trying to program an EDACS narrow system (Oncor). I know the frequencies however I'm not sure of the LCN order. Is there any way to determine this?
At present I just have the four frequenices programmed in #1 through #4 however my PSR-500 does not follow the system. I've never heard any two-sided conversations, just one side.
ElroyJetson
Is it in our database?
If so, the listed order should be correct. Try it.
If the order is wrong, it can be a pain to figure out what's wrong with it. It takes time, trial and error,
and hopefully a good spectrum analyzer or a stack of radios, each tuned to each system channel
in conventional mode.
Elroy
EDACSTECH
Ocean City,MD
Try starting with the lowest frequecy and ending with the highest. If frequencies have not changed for rebanding or other reasons, M/A-COM normally goes low to high in frequency order.
mikebennett
Sherman, TX
That's the way I had it set up with the lowest being number #1 and the highest #4. It's listed in the database but apparently a lot of the sites LCN is not known, including this one.
Most of the confirmed ones are set up that way but then theres some that start off with #9 and go up from there. I'm wondering how these were discovered?
ElroyJetson
By means of a lot of effort, and in some cases, some good detective work. You'd be surprised at how
much customer information can be obtained from the trash can behind the local county radio shop. ;)
And of course, some of it comes from insider information.
Elroy
