edacs multi site ????
scannerface27
Jurupa Valley, Ca
ok i have a 396xt and sometimes follow riverside conty sheriff, which is an edacs standard system.. In the scanner i have it set as my 12th system, with one site for west. I would like to add trwo more sites, but am confused on what sqk to give them.. i dont want to put them in as seperate systems.. any suggestions?? if you want to see the system setup it is at riverside county sheriff in southern california..thanks
scannerface27
Jurupa Valley, Ca
System Frequencies
Red (c) are primary control channels | Blue (a) are alternate control channels | Site Map(s): FCC Callsigns RR Locations
Site Hex Name
001 1 West 01 866.21250 02 866.26250 03 866.71250 04 866.76250 05 867.21250 06 867.71250 07 868.21250
08 867.26250 09 868.26250 10 868.71250 11 867.78750 12 868.78750
002 2 Central 01 866.31250 02 866.81250 03 867.31250 04 868.31250 05 867.81250 06 867.76250 07 868.81250
003 3 Desert 01 866.23750 02 866.73750 03 867.23750 04 867.73750 05 868.23750 06 868.73750 07 866.78750
08 867.28750
004 4 Blythe 01 867.21250 02 866.71250 03 866.21250 04 867.71250 05 868.21250 06 868.71250
005 5 Santa Rosa 01 866.28750 02 867.78750 03 868.28750 04 868.78750
006 6 South 01 866.23750 02 866.73750 03 867.23750 04 867.73750 05 868.23750 06 866.78750 07 868.73750
08 867.28750
W2SJW
Senior Member
Northwest NJ
I have a few mutli-site systems in my 396XT that I have ALL the sites set as the same SQK. I just let it roll-thought all of them that it finds control channel data on.
If you want to hold on a specific site, press the HOLD button for approx. 3 seconds, and the unit will beep. The HOLD icon on the screen will flash as well. Now, you are held on that specific site, and the unit can then resume scanning talkgroups. You must do the same long-hold press of HOLD to make the scanner go back to looking at all the sites in order.
I did not want to waste SQK's on mine as well...
thewenk
Idaho DB Admin
Eastern Idaho
Just add your additional sites under your 12th system and assign the same (or different) SQK(12) to each site. With trunked systems SQKs are assigned by site, not by system.
I monitor Riverside SO with my 396XT when I visit family in Riverside. I also have 5 TG groups assigned under my primary Riverside SO System (1-Central TGs, 2-Cross County TGs, 3- Patch TGs, 4-Southwest TGs, 5- West TGs), but you can assign all TGs to one group if you wish.
Dave
