EDACS Narrowband LCN
oilmillcharlie
S.E. Ct.
Is there a way of determining the LCN of an EDACS narrowband system when the frequencies are known but the LCN isn't? I have multiple scanners if that can be part of the solution.
B.K.
rmiles
Bel Air, MD
I think etrunker will do it for you. Do any of your radios have a discriminator tap?
WayneH
Forums Veteran
Super Moderator
Sitting in an airport somewhere
If you can't run any software app you'll need to program them in conventionally and use a somewhat challenging method of putting them in order by listening. Since most systems start at LCN 1 and go up the frequencies are assigned by the system in sequential order. As soon as someone is done talking on LCN 1 the next transmission will occur on 2 as long as it is withing a certain time limit. The system will need to be very mellow though.
