I did a Google search for EDACS +Moscow. I see reference that Moscow is supposed to have an EDACS system in place since 1997 for various public service entities. I'm going to guess that what you are logging is this system...
Ericsson sells radio system to Moscow. | Europe > Eastern Europe from AllBusiness.com
From what you show, it looks like its a single system with multiple sites [networked]. As others have mentioned, there is no "easy" way to determine all of the active frequencies on each site other than regularly scanning the system for new LCNs associated with each site.
The few EDACS systems I have monitored do rotate control channels, but not always daily - perhaps weekly. And, there is no guarantee that they will rotate. For your sake, I hope they do rotate frequently - as that will help you to identify known frequencies for each site in the networked system.
What I would suggest [and ask of you] is that you submit any information you know about this site to the RRDB. Once it is listed, perhaps more people from Moscow will see information about it on these forums and will post information. Then, as you identify new frequencies associated with each of the sites, you ccan submit that information. Sure, it benefits everyone else when you submit it - but it also benefits yourself because having that documented in the format set up in the RRDB is very useful - very easy to read and make sense of.
You should log:
a. frequencies seen, the LCNs (i.e. C:07) and the Site (i.e. S:02). And if you are running Unitrunker, then you can attempt to log talkgroups active on the system. Obviously you won't be able to track mucch until you monitor multiple frequencies per site and are able to add them to your scanner as an actual system in the proper way.
Hopefully we can be of help to you, over time. I'm not sure how well you understand English, but hopefully well enough that our suggestions can help you out.
I'd recommend using one scanner to track the trunking channels on the system and then use another scanner to actually start attempting to program in the individual sites. Or if your other receivers are not sccanners, perhaps you might want to use one of those receivers (with a discriminator tap) to scan/monitor control channels and then use your PSR to attempt to track the sites once you get enough frequencies.
Mike
