EDACS network
DRomanello
How do I find out the specific sequence for programming EDACS network in my area? I just bought a BCT8ss Trunk III and I'm confused.
scanfan03
Houston, Texas
It is very hard and confusing for a beginner and most advanced users too. If you tell us what system you are wanting to know about, someone here can probably help you. Or you can check the Database here for the system you are wanting to monitor.
ctrabs74
California, PA
1. Check the RR Database for the specific EDACS system you're planning to program.
2. The freqs for EDACS system are listed in Logical Channel Number order (LCN); the freqs for that particular system must be programmed in that specific order (we'll use the Lower Merion Twp., Pa system as an example), ie.:
LCN01 - 460.275
LCN02 - 460.350
LCN03 - 460.450
LCN04 - 460.525
These frequencies must be entered in that specific order, starting with 460.275, then 460.350, 460.450, and 460.525.
3. Review the list of talk-groups associated with that system, and enter them either in AFS format (04-041) or DEC format (545) and continue with each TG until complete.
As far as programming it into your particular scanner, I can't really answer that. Hopefully, this will give you a start on how to program EDACS systems into your scanner.
DRomanello
I’m trying to program the Hillsborough County Sheriffs Office of Florida. The scanner instructions state that the input sequence of frequencies are crucial for EDACS. The system frequencies are split up into two groups, east and west. The first time I installed them, I put them in order by how they are listed on the RR database. I was able to listen to a few conversations. The second time put all 30 frequencies in numeric order. This doesn’t work at all. Something just isn’t right. Thanks for your help.
DRomanello
mciupa
Canadian DB Admin
Moderator
Hi D , Put the East site in one bank starting at the first channel in the bank. For the West site , go to the next bank and starting again at the first channel of that bank enter the West freq's. Do not put the LCN's starting at a random location in the bank , it just won't work. Either will "doubling up" two sites in one bank.
give it another go , you have been one patient guy waiting since last month to program this system. I'm sure you will "see the light" and get it figured out soon.
Good Luck :)
