EDACS Programer need help with GRP Feature
My question is i noted in a San antonio EDACS Jaguar 700p
there was a (GRP) Botton on a given system like San antonio Fire Fleet
if you hit the (GRP) botton you will get more Talkgroup fleets on given
system i have been putting groups inline Past channel/switch 16 posision
and noted you will not get the groups after the Channel/switch is at 16 Groups
you can still rx scan groups after that but have no way of getting manually to groups
how do you get this Feature to work
If I understand your problem correctly .. you cannot get past 16 talkgroups with your dial on the top of the radio ? To resolve this, assign GRPUP and GRPDN to a couple of buttons on your radio.
ok my bo-bo i programed radio with the talkgroups
and if you have more then 16 talkgroups the (GRP)
botton works like GRP = 1 /. GRP =17 / GRP = 33
under the same edacs site not a real programer feature
just a full face radio feature scan models dont have the option unless
programed by up/down key but you will lose system slection
Radioman96p71
If you assign one of the Menu items to GRP SEL, you can achieve the multiple group banks. Just hit the Menu button, select GRP SEL and then you can up/dn arrow thru the banks. Use the top knob to select groups 1-16 of each bank.
motorolahead
Texas
Lower Colorado River Authority
Does anyone have an Orion Codeplug for the LCRA statewide frequencies in Texas? They are a 900 system EDACS and I would like to monitor. Even an 800 EDACS load from the Houston area would be nice.
