mrm1951
I know that the 396 is going to be a great scanner for the Motorola system but what's being done to monitor the Provoice systems like the one in San Antonio?
mrm1951 said:I know that the 396 is going to be a great scanner for the Motorola system but what's being done to monitor the Provoice systems like the one in San Antonio?
UPMan said:The issues here is the same as in San Antonio and several other major cities (and the State of Florida): They have chosen an EDACS ProVoice system. This system is not necessarily encrypted, but rather is using a vocoder scheme that MA/COM will not license to scanner manufacturers.
Even if they allowed the public access, it would have to be by allowing you to purchase a $5,000 HT that has the PTT button disabled. Your RS/Uniden scanner is never going to be able to monitor the system.
lschmidt said:Why does MA/COM seem to have so much power over Uniden,RS and
others when it comes to keeping them from making scanners that could
monitor it's ProVoice and Open Sky systems?
Voyager said:. . . Hope congress passes a law mandating an interoperability standard such as P25.
Joe M.
Although I agree in the legality, it would seem that "Homeland Security" and interoperability would force the issue.N_Jay said:Voyager said:. . . Hope congress passes a law mandating an interoperability standard such as P25.
Joe M.
Never going to happen. Too many "States Rights" issues.
It would be like the Feds dictating what type of gun, or what type of car they have to buy!
rdale said:You can interoperate just fine with ProVoice/APCO25/conventional so that's not really an issue.
Voyager said:rdale said:You can interoperate just fine with ProVoice/APCO25/conventional so that's not really an issue.
You CAN? Well, then, any P25 scanner should monitor a ProVoice system just fine if they are interoperable. :wink:
N_Jay said:Voyager said:rdale said:You can interoperate just fine with ProVoice/APCO25/conventional so that's not really an issue.
Yep, its all in the planning.
Yes, interoperation is easier with everyone using the same technology, but you can build plans that work around the problems of different systems.
Voyager said:N_Jay said:Voyager said:rdale said:You can interoperate just fine with ProVoice/APCO25/conventional so that's not really an issue.
To me, having a common channel such as the I-CALL and I-TACs are no replacement for TRUE interoperability. With true interoperability, the people on one system can monitor the goings-on on an adjacent system. Having to rely on a dispatch center to relay that a car is heading your way is no replacement for hearing it first hand. It wastes time, and there is ALWAYS loss of content/detail in any human-relayed message. That's a fact proven countless times.
You can equip all the units with CBs so they can talk to each other and call it interoperability. You can also give everyone a cell phone. Both are interoperability to a point, but it's not EFFECTIVE interoperability. There is no replacement for first hand communications.
Joe M.
