EDACS Question
Caddop22
Huntsville, Al.
PRO-95 Scanner
Hi all,
I am wondering if the following is correct when programming edacs into a PRO-95 scanner.
Bank 8-0 ON
ID No. 00
ED: 0810
any text tag
Then I have on bank 8 the following
800...........+FM
0.00000
Bank 8 Ch 00
text tag
At 801 Ch 01 I input the first frequency starting in lcn order up to 805 Ch 05. All channels are set to +ED.
I also was wondering if it is possible to put edacs into 2 differnt banks if they are two different agencies. For instance I have Alabama state in bank 8 and airport authority in bank 9. I hear no traffic except when I scan them manually. I am at a loss as to why this is happening.
Thanks for any input.
K
Ohio
Caddop22 said:
PRO-95 Scanner
Hi all,
Bank 8-0 ON
ID No. 00
ED: 0810
any text tag
800...........+FM
0.00000
Bank 8 Ch 00
text tag
Thanks for any input.3
One EDACS TRS per bank. So if there are then EDACS systems within your area and your radio scanner has ten banks then you can put one in each bank.
Check to see if you have the frequencies programmed in LCN order.
NeFire242
Nebraska
Yup the channels are not in LCN. Make sure both the channels and the entire bank is in EDACS mode as well.
Caddop22
Huntsville, Al.
Thanks for the replies.
I was curious about this:
800...........+FM
0.00000
Bank 8 Ch 00
text tag
I wondered if this being on +FM was causing a problem, but I see that you can only change it to AM or FM Mode.
I checked all the LCN's and they are in order, I guess there is not alot of traffic on these systems around here or I am too far away........
Thanks again.
K
n3ncn
Trinity,North Carolina
I'm not sure but if I remember right when I had mine I still set the mode in channel 00
(800) with no freq. but mode was E. and L/O 800. Are you in open mode + ?
Also do you hear the control channel very important.. Just a thought
For your last post PGM Trunk MODE should bring up AM, FM MO, ED, and I believe LTR to get you into trunk mode
Caddop22
Huntsville, Al.
n3ncn,
I am only able to set mode for channel 00 to AM or FM, I guess because there is no frequency input here. Yes I am in open mode and can hear the control channel in Manual, but it is just static.
Thanks,
K
n3ncn
http://support.radioshack.com/support_electronics/doc69/69487.pdf
PAGE 28 will help you . If you do it step by step the way this book in the link says and it does not work. It's broke
If your control channel has alot of static despite the noise sound the contol is you must relocate the scanner to a location where the irritating sound of the CC comes in clear. that could be a big part of your problem,
Ohio
1.) Make sure that your radio scanner can pick up the Control Frequency loud and clear.
If it cannot, then get a better atenna or move your radio scanner to another location.
2.) Make sure your frequencies are set to ED.
3.) If this radio scanner requires that you set your Talk Groups to EDCAS also, then do it.
Ohio
This is a DUAL trunking Radio Scanner. It can ONLY trunk tack MOTO & EDACS. NO LTR.
n3ncn
Quote "and I believe LTR " That means I am not for sure.While picking the thread apart,Most of us have noticed that he is working with an EDACS system anyway
K I would hope I am helping some. I am working from memory two or three years ago. But I'm not staying on here to have my help to you picked apart. If you would like for me to help you further with this I am at n3ncn@nc.rr.com If not of course continue with the thread. Pleanty of people out hear to help. 73's Mark N3NCN Pikeville, NC
Caddop22
Huntsville, Al.
I appreciate all the help from everyone. I believe that the scanner is setup correctly, but I am too far away or there is little traffic on this particular system. I read that edacs has a smaller usable area and I may need an antenna. I will take the scanner outside and see if reception improves.
Thanks again,
K
Ohio
Thanks again,
K
You might want to try to antenna from Radio Shack:
http://www.radioshack.com/product/i...2&kw=radio+scanner+antennae&parentPage=search
If the above link does NOT work, go to http://www.RadioShack.com an search for
Catalog Number: 20-283 or Model Number: 20-283
