I think jpm was trying to post a hint for others, not asking for help. The problem is that he didn't state what he was attempting. Let me give it a try.
The book he refers to is probably any Uniden Owner's Manual because Uniden choose those terms. Yes, Wide = Standard, Narrow = Narrow, and SCAT is a single channel trunking support system.
None of those are associated with spectrum uses, they deal with the data bandwidth of the EDACS control channel. Standard (Wide) = 9600 baud and Narrow = 4800 baud. To be frank, I am unsure of what SCAT uses, but assume it is the same everywhere.
Both Standard (Wide) and Narrow control channels can be used on SNFM (or as Uniden calls them NFM) frequency bandwidths (11K) or NFM (or as Uniden calls them FM) frequency bandwidths (20K). The most common type of EDACS CC is the Standard (hence the name). All current trunk tracking scanners can track those. I am unaware of any GRE built scanner that can track EDACS Narrow.
Is this where you were heading jpm?
