I've encountered an annoying issue with the scanner on an EDACS system where it stop receiving a particular frequency for about a second, then tune back in again, resulting in missing whatever was said during that time. I've tried using second conventional scanner simultaneously to confirm the transmission continues despite the Pro-106 cutting it off. The reception is crystal clear, if only the scanner would simply remain tuned in. When it resumes it's typically still on the same frequency. Any ideas? I've encountered a related issue where the frequency will actually change during the course of the transmission, and this can also result in losing some of the conversation. The former issue occurs on all talkgroups in the system, while the latter issue seems to be specific to a select few.
