EF Johnson 242-7184
Central AL
Hello everyone, I just picked up two of these radios and want to reprogram them. The only programming cable I can find for them costs $40 which isn't worth it to me, so I want to make my own.
I found this this website which includes a schematic for building a programming cable. It seems fairly easy, but I need some help figuring it out as there are a few areas I don't quite understand.
Here's the schematic in question:
Here's what I need to know:
The guy at the website I linked to used 2 50V,.01uF, Ceramic Disc Caps but I don't see those in the schematic anywhere. He says to use a +5.0V 1.0A TO-220 Voltage Regulator so you can use a 12v power supply, is that where the disc caps come into play? If so, how do I hook them up?
Also, where does everything need to be grounded to? The power supply ground?
Thanks for any help.
WX9EMS
Lake Geneva, WI
To answer your question, yes, he is using the disc capacitors with the power supply. I built a few programming interfaces around the MAX232 and I have never used any disc capacitors with the 7805 voltage regulator. I usually use a 1 µF 25V or a 10 µF 25V electrolytic capacitor with the 7805, it depends what I have on hand at the moment.
I can't say that my design is any better, but I know my design works every time without any issues.
Your ground will be a network between the pin 5 of the DB-9 and the ground pins of the radio. All ground connections will ground through this net.
Good luck!
Central AL
Thanks for the help!
I should be headed in the right direction now. If you have a way of providing 5v can you just skip the voltage regulator all together and feed right in from your power supply or will that cause problems?
mancow
N.E. Kansas
I wouldn't skip the regulator.
If you use a MAX233 you don't need the capacitors at all.
WX9EMS
Lake Geneva, WI
You can get away without the 7805 regulator as long as your voltage stays below 5.5v.
You can use the Max233, if you have the extra space (it is a 20 pin DIP vs .the Max232 is a 16 DIP) and the cost is usually twice that of a Max 232, but it does have its upside, the designing and PCB building process is much more simplistic with the Max233 when real-estate isn't an issue.
Central AL
So basically if I use the Max233 I won't have to use any capacitors, just make my connections to the power source, radio, and DB9?
I may go that route just to keep it simple.
Central AL
Now that I finally have time to get back to work on this I came across a few things while I was getting ready to order parts.
I found this while looking around and I'm wondering if I can just use it instead of assembling my own. Not that I'm opposed to assembling my own but this would save some time soldering and doesn't cost too much.
Am I missing something or would I just be able to buy this and then hook up my 5v, TX, RX, and GND to it and be good to go?
Central AL
Went ahead and bought the TTL converter I linked to and it worked fine. I still had to use a 7805 regulator for 5v and I set that up on another board.
Was able to program both radios with no problems.
Thanks again for the help.
