Ef Johnson System Key
Riddlehr
I am trying to program a Ascend es radio for a scanner on a p25 trunking system and need a system key. What would be my next steps?
Michigan
These radios cannot be programmed for a passive scan on a trunked system. If you proceed forward you will be transmitting on the trunked system with affiliations.
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
The EFJ radios, AFAIK, can not be programmed to passively monitor a trunk system. If you program a trunking personality, it WILL try and affiliate.
Thunderknight
Bletchley Park
Hand it to the system administrator and ask them to program it for you.
If you don't know who that is, or are not authorized, eBay the radio and buy a Unication G4/G5.
(That may sound harsh, but it's a serious answer)
cmdcomm
The Woodlands, Tx
We program them with the “scan hack” all the time. You do need a system key to do it.
APX8000
Sarcastic Member
AES-256 secured
Scan hack ? Explain ? For example, BK Radio KNG radios can be programmed with a system key that opens up the trunking parameters. However, once you click RX only personality, it darks out any TX info and the radio will not affiliate to the system. On the opposite end, the Kenwood NX series, even if programmed as a RX only personality WILL affiliate with the system.
clbsquared
Isle of Wight County
He's referring to the Non Affiliate method for programming Motorola radios.
Sent from my HTC One A9 using Tapatalk
