EF Johnson
KD0NDO
please move to the correct forum if needed. i couldn't find one for this type of radio.
can someone please help me track down the software for this radio.
EF Johnson 5300
Model # : 242-5387-101-MAAB
what is the name of the needed software, and do these have some type of rib like Motorola has?
Thank You,
Martin
bezking
On the Road
You need the PCConfigure software which is only available through EFJ dealers. Expect to spend around $350 for it. I don't recall offhand if some sort of interface like a RIB is needed. I don't think so but I don't really remember...
KD0NDO
do you know which version i would need? i was reading that you can read them with different versions but if you don't have the right one for the radios firmware you could damage it
KD0NDO
also could someone decode that model no. for me?
thanks
jim202
New Orleans region
EF Johnson 5300
Thank You,
Martin
When you first turn the radio on, there will be 2 sets of numbers that will show up on the display. You will need this information to figure out which version of the PCC you will need. They will only show up for a brief time, so you have to be fast. It may take several tries to get the numbers.
Then you will need one of EF Johnson's RIB boxes (part number 023-5300-000). It has a cable that will plug into the mic connector and will have a serial connector to go to a computer serial port. The software will run under Windows XP just fine.
KD0NDO
EFJ * V200 shows up when it is powered on then the zone is displayed shortly then the channel name appears
