Effects of grounding a DISCONE antenna
eaf1956
Evansville, IN
Does grounding a DISCONE antenna improve it's performance? Is grounding ONLY for lightning protection? Is grounding even required on a DISCONE? Let the experts answer these quesions for the users of this forum.
zz0468
Banned
Grounding it WHERE? Discones are generally designed to be pipe mounted. Grounding the pipe it's mounted on is required for safety, but really would have no or minimal impact on performance. Also, you should ground the feedline in several places, again for safety. Actual performance isn't likely to be affected either way.
