Was wondering what opinions i can get on this subject , example if you have a discone scanner antenna mounted on the same mast with a tv antenna or two tv antennas would the fact that those tv antennas being so close have an effect on the discone ? perhaps making it receive more from the direction the tv antennas are pointed ?
I ask because not long ago i was running a scanner on the built in antenna , near it was a tv antenna the type with the knob that changes the length of the rods artificially in 12 different positions , it was not hooked to the scanner but i found by accident if i rotated the knob on that tv antenna it made the noaa weather weaker or stronger , also when a fire call came in it had an effect.
So if there are other antennas on that same mast up on the roof could it benefit or hurt the discone ?
