EFHW 8010, hung as a inverted L ?..
k8niv
I have the endfed hanging as a inverted L, my transformer is about 24-30" off the ground and it is grounded there also, the wire goes vertical about 30-33ft and have the wire antenna is on a pulley, and goes the rest of the way across the back yard horizontal...the tail insulator is about 10-12ft from touching the tree limbs where the rope is also on a pulley before it crosses the tree limb.....it is been feed with about 50ft of RG 213 coax, which at the present comes in the shack window to the back of my radio, which is a Kenwood TS-590SG radio, I just run a 100 watts, no amplifier...
I have ran these antennas setup like this in the past but never in this location....
Question I have is, I don't see any indications of any RFI in the shack, or bothering anything in the house, can it still be some stray RFI bothering the neighbors stuff ?...
Skypilot007
Medford, NJ
Is the antenna closer to your neighbors house than it is to your house? If that's the case, there could be a chance that you are not having any RFI problems and your neighbors could be. Have your neighbors complained?
