EFJ 5100ES bits
ergbert
FN22
Thanks to the wonderful internet junkyard that is eBay, I just got my hands on an EFJ 5100ES limited-keypad model, in UHF-380 split. Wow what a brick, I think that in an emergency it could double as a bludgeon! Works well despite a tweaked antenna, but I've found a source for replacements. Having much less luck sourcing a cover for the speaker mic/programming port. I don't have a speaker mic, and my OCD doesn't think that bare contacts are great in outdoor usage.
Does anyone out there have a source for these covers, or have a few floating around a drawer somewhere? Not looking for a handout or freebies, just a source. Local radio shops have been less than helpful, especially for older models like this.
jaspence
Michigan
Try one for th3e Motorola XTS 3000 series. I also have the EFJ-5100, and use the same cover on mine. Most batteries are also interchangeable, although a couple I have don't fit the EFJ. My EFJ outperforms the Moto on P25 simulcast
ergbert
FN22
Thanks! The XTS covers certainly seem plentiful. I mostly got mine to play with P25 on 70cm... Climbing the learning curve now.
I am a lineman for the county.
Motorola antennas will work on your EFJ.
Or just contact an EFJ/Kenwood dealer and get a new antenna.
We used 5100's for a few years on my trunked system. They were good radios and much easier to program than Motorola's. I've still got a few kicking around in a box.
ergbert
FN22
So far I really like it. The user interface seems to be pretty well thought out even for a limited-key version, and the amateur world could take a lesson from the sheer user friendliness of the FPP implementation. It’s reinforcing my preference for repurposed commercial equipment in the amateur bands....
Yep, got rid of all my amateur only gear many years ago. All my personal stuff is Motorola and a few Kenwood's thrown in. Memory capacity is enough that not having a VFO doesn't matter. I have plenty of room to program in everything I need as well as all the simplex frequencies. FPP makes changes easy if needed. Receivers are often much better. Some of the feature sets on commercial gear is much better than the ham stuff. On the mobiles, an ignition sense controlled power is a nice setup.
Have not missed any of my amateur rigs since I sold them.
Plus, at work, I can use them on my Part 90 frequencies legally and without modification.
ergbert
FN22
I got my EFJ cable from ebay seller KJ6ZWL. Flawless, and much cheaper than the EFJ one...think it was $29 or so. Firmware flashes just fine. However, my radios (I have acquired a few more just recently) did not cost me anywhere near $2500, and don't belong to anyone else, so if I bonk one I'll chalk it up to a learning experience and move along. But, I am not a career radio person, just a hobbyist.
jaspence
Michigan
I have successfully flashed several EFJ 5100s with the kawawall cable. I use a Windows XP compter with a true serial port, not a USB to serial adapter. You might also have good luck with 32 bit Windows 7, but stay away from 64 bit machines on the older radios.
ergbert
FN22
I'm actually using an old Asus machine, running Windows 10, 64bit, and an FTDI USB-serial cable. Not a hitch. Just as a data point...
cmjonesinc
I've been using a kawa serial cable for years on the efj's and have yet to brick one. Those are pretty robust radios and the price is right on them. If you don't need a lot of bells and whistles they are a rock solid rig.
