EFJ/Kenwood and SmartConnect
BryanTheRed
Ø
NC
Does anyone know if the Viking line up will work with Motorola SmartConnect? We have a huge issue with coverage in hospitals and at our out bases. I was thinking this may be a good option for coverage, however we use Kenwood portables. Can anyone share experiences with me? Thanks!
GTR8000
NY/NJ Database Guy
BEE00
No. Kenwood/EFJ subscribers lack LTE capability, so there is no equivalent to MSI's SmartConnect. Even if they had LTE capability, they wouldn't be compatible SmartConnect.
BryanTheRed
Ø
NC
I was under the impression this worked via wifi. Moto APX radios other than the Next do not have LTE.
There is no standardization in this part of the industry, and they are not compatible, either WiFi or LTE.
I'm not even sure Kenwood has a WiFi solution yet. They are kind of behind the curve on this.
KevinC
Other
Super Moderator
Home
I’ve said it before, that’s one of the problems with the P25 standard. They don’t specify how to implement certain features. So Kenwood, MSI, Harris and whoever do it their own way.
GTR8000
NY/NJ Database Guy
BEE00
Right, the NEXT connects via LTE, while the 6000BN and 8000 can connect via WiFi.
Still doesn't change the fact that Kenwood/EFJ and SmartConnect are incompatible.
I sat in on a session at IWCE where DHS/CISA and a few others were discussing this exact thing. There are suitable standards in 3GPP, and they are working towards that.
kd4efm
Florida
Wifi is a feature that allows you to program your radio radios over internet (or OTIP) connection.. you will be able to connect your radio to an access point, and as long as your computer is connected to the same access point, you can write codeplug changes, or update firmware on your radios as if you were directly connected to the radio.
wsp44
This is one area where JVC Kenwood doesn't currently have a path forward with ATLAS that Harris does with BeON. Broadband integration.
Behind the eight ball, the VP8000 would be a game changer if they had broadband integrated into it, and a road map to integrate broadband into ATLAS.
The problem is no real standard for broadband integration adopted as part of the TIA P25 standard...yet. It's 1993 all over again: instead of SmartNet it's SmartConnect, EDACS=Beon, and LTR Multi-net=nothing?
Exactly. P25 is old enough to vote/drink/be drafted. They need to get their butts in gear on this now. They've already missed the boat. Like I said above, 3GPP has suitable standards in place.
MTS2000des
5B2_BEE00 Czar
I think the two incumbents like it the way it is: proprietary walled gardens are in style:
Apple/Samsung
They set the pace for all things tech these days. P25 system manufacturers know broadband integration keeps one coming back to the table and keeps third party subscriber "creep" into their SAS powered world to a minimum.
