egusd radio question
clanusb
Northern CA
is the school staff, security, principal, janitor, etc
are they on the 800mhz trunked system? i know they use the ht1250 with a full keypad, and the ant. looks to be a 7in 800mhz whip antenna, but i haven't been able to pick anything up on my close call, or find anything in the database about the campuses themselves.
any help is greatly appreciated.
Sac916
Just to confirm, you have the freqs from these two databases;
EGUSD Conventional
http://www.radioreference.com/apps/db/?ctid=216
EGUSD (recently rebanded)
http://www.radioreference.com/apps/db/?sid=1875
Also check Itinerant freqs
http://wiki.radioreference.com/index.php/Common_Itinerant_and_Business
clanusb
Northern CA
yeah i tried channel 1, 2, and 3(pd?). (on my bc350c)
i didnt hear anything all day, im only about .75 away from one of the highschools, and im right around the corner from an elementary school, havent heard anything on any of the channels.
(im aware its summer break, ill listen more closely when school starts up again in late august.) thank you for your help.
i was told my BC246T is not able to scan their trunked system..?
Sac916
Not true. You will have to program the new freqs (since after rebanding) Make sure you have it in Control Channel Mode only.
clanusb
Northern CA
how do i throw it into control channel mode?
same as the SCRRS?
it would be nice if they gave the option to put conventional channels into the same system as well.
Sac916
same as the SCRRS?
Within the scanner, in the menu system, edit system options, select EGUSD system you programmed - Set C-Ch ON ( control channel on ) and also make sure you have the correct Control Channel freqs programmed. 852.85000 and 853.82500
kma371
ALso found 451.7375, 451.4875 licensed to EGUSD. Try those
clanusb
Northern CA
sorry its been a few days.
i havent heard much, but then again school is technically still out.
thanks again.
northzone
Northern California
NO, that will not work. The 246 will NOT track rebanded systems even in the CC only mode. Until it gets a firmware upgrade it does not know what channels to go to. The Pro-96 can be made to work by entering a custom table, but the 246 does not allow this on 800.
Sac916
Okay. So would it be correct to say;
The 246T will be able to track the newly rebanded system once Uniden releases a new firmware version.
WayneH
Forums Veteran
Super Moderator
Sitting in an airport somewhere
im guessing there isnt going to be a firmware update anytime soon?
Since Uniden went straight to producing a new scanner, no.
I think all the Uniden and firmware updates hype for rebanding was a pipe dream. Uniden never admitted it would happen. People just ASSumed. The reality is that you can only support rebanding through tables like GRE does it. To include the calculations would be patent infringement as Motorola filed patents for the process. That's why I think GRE hasn't included a band plan in its firmware updates yet. What Uniden will do, I don't know. If they go the table route GRE can claim Intellectual Property rights.
Uniden is no longer the king of scanners...
