At the moment, this is what I've got so far.
MOTOTRBO Capacity Plus trunking system.
451.3500 MHz, LCN: 1(?), Color Code: 4
461.1500 MHz, LCN: 2(?), Color Code: 4
TGID Description
1 Snowmaking / Grooming
2 Tac
3 Ski Patrol / Medical Emergencies
4 Tac
5 (No hits)
6 Lift Operations
7 Tac
8 Parking/Base Operations
9 Tac
10 (No hits)
11 Administration
22 Broadcast/Announcements
If someone has the ability to confirm the LCNs (e.g. DSD+), that would be great.
One problem with scanning this system is that there is another agency on 451.3500 which causes the scanner to stop and try and decode the weaker signal. I haven't checked the location of the competing agency, but if you're near it, it may make monitoring this system difficult.
I've labeled some channels as Tactical. They are basically used for people who move their conversations off the main channels. But given that it's early in the season these IDs might actually be dedicated for things like ski school and racing events but are not in use yet.
The users often refer to channel numbers, analogous to the
previous analog system, and most of the time they match the TGID, but sometimes they don't.
If you're not familiar with Capacity Plus, 2 voice/data slots fit on each frequency and the control channel roams the slots, as do the voice conversations. Although their FCC license is for 5 repeater frequencies, they are currently using only these two. I'm mostly using a BCD996P2 with DMR upgrade to monitor this system.
