Electroline EDA-UG2802 50 or 75 Ohm
p-o66601
Hi,
My antenna feedline is 50 Ohm. I want to purchase a electroline EDA-UG2802. I saw that I had to install a 75 ohm terminator on the unused outputs. is it necessary or I can put 50 ohm as my cables to the scanners?
Thank
Sorry for my bad english I speak french :p
900mhz
You can use 50 ohm cabling. It would be wise to terminate unused ports...75 ohm would be fine for those terminators.
737mech
Clark County, NV.
75 ohm f type connectors are ok to use, or get f to BNC and use 50 ohm cables. I use the electro line they work great!
