Just picked up my second Electroline FM Amplifier. Good from 1.5mhz to 2.0 Ghz. It's a 2 way. A lot cheaper than the Stridsberg.
It is rated at +11db Amplification on each output.
My question, What is the signal loss "receiving only" scanner use, using 30 feet of RG6 from a UHF Antenna with Ground Plane in the attic to the amplifier at my scanner feed PC. The scanners are both BC125ATs. The line loss calculators online only do transmit loss.
