Elizabeth Board Of Ed School Frequencies
NYC
I was able to confirm these frequencies and DMR Color Codes used by Elizabeth Public Schools Staff and Security. Unfortunately my DB submission was rejected, most likely because I could not identify which specific schools used which frequency. But I feel folks should still be aware that these frequencies with the DMR Color Code listed below are used by Elizabeth Schools:
462.1875 CC1 DMR
464.9125 CC1 DMR
462.4625 CC1 DMR
464.525 CC14 DMR (Buses)
My guess is it was rejected because you didn't list what each freq was used for, other than the bus frequency. If they rejected your submission they usually give you a reason and chance to make corrections.
NYC
Also, I am
Correct and I understand why it was rejected. Hard to tell which school is on which frequency. But still good to put the info known so far out there, in case someone else can add in more info.
Appears they are available for use at all schools based on the FCC license WQFQ242 (the only license held by the School Board) wording and locations. However, I suggest you check out 464.525 to make sure it isn't 464.5125 as listed on license. This info should help get your submission approved.
FRN: 0007577703
ELIZABETH BOARD OF EDUCATION
The license(s) referenced on the reverse side authorizes operation of a system of one or more facilities or frequencies ...
GTR8000
NY/NJ Database Guy
BEE00
You're looking at the wrong license. 464.525 was not part of his rejected submission, but has been listed in the database for quite some time. The correct license is KNGW719, as listed.
NYC
