I answered your PM also. But on the DB page it also says:
Latest News Update Posted on 2008-04-30 20:41:39
The system has moved to the new rebanded frequencies. Please verify the system information above and submit any changes.
If you use a PRO-96 or GRE500/600 you can use the table below to properly track the system. See the forums for more information.
Lo Hi Step Offset Base Freq
440 559 25.000 440 851.025000
000 719 25.000 0 851.012500
720 759 25.000 0 848.000000
I believe they ramped their power down big time. I noticed this happened for Ceres and Turlock systems at the time of rebanding or soon afterward.
I can't even pick up EGUSD from home standing on the roof with a handheld.
Same here. I tried to listen after I saw these posts and didn't hear anything. I was at Franklin/Dwight at the Regional Sanitation plant at the time.Well, they must have lowered it below 1 watt because I cant even hear it in Elk Grove.
Last month I heard the system so it's odd. Maybe someone can scope out where the site is supposed to be located. KMA, I volunteer you since you're close.![]()
confirm you are listening to these freqs:
851.7000
852.2250
852.8500
853.8250
I know a certain someone who normally monitors this forum who has a family member who works for EGUSDPD, maybe they can ask if they are still using the same radios and report back?
There's got to be something up. They go through the motions to reband and then shutdown?
its the same radios. i hear it everyday on the bus when a fam member gets picked up and dropped off.
ill ask a security guard tomorrow.
why are they issued HT1250's model 3's 800mhz. ?? seems like OVERKILL to have a radio that is capable of so much, yet only have 2 or 3 simplex freqs programmed, that are constantly used. (chans 1 and 2)
high schools are usually on chan 1, junior highs usually on chan 2. i never hear chan 3 operational.
