I do believe the listing as an Capacity Plus TRS is wrong from information received. Closer monitoring is needed, as this appears to be an Conventional DMR system. Also on the Elkhart County needs more love theme: Ivy Tech's North Central Campus, need the Color Code, TG, Slots for this one. Need much closer attention to the ERS-OCI 800 MHz sites up that way as they now all have added DMR emissions listings and ERS-OCI is actively doing work to add 800 MHz into the TRBOConnect systems. I will also be doing some updating for the County DPW type services etc to reflect new info on the DMR systems they are running.
