For those who want to embed a HTML 5 audio player with stats instead of the default one, here is a tutorial how. You may need to adjust the width and height values to fit your needs, but the values listed there worked best for me.
See it here: http://scanpei.net/live.php
If you require assistance, just ask and I'll try my best to help.
1. Copy and paste the code above into a text document such as notepad so you can make changes.
2. Find your feed on Broadcastify, and listen using the HTML 5 player. Right click on the web player page and choose "View page source" or something similar. You want to see the coding for that page.
3. Find the <audio> tag and copy the URL (source src). It should be a relay.broadcastify.com URL. Paste it into the code replacing "YOUR FEED URL (SOURCE SRC) GOES HERE".
4. Replace "FEED-ID" and "API-KEY" with your own values.
5. Once all your own values are in, copy and paste the code into your own website.
6. ENJOY!
EXTRA: If you want the feed to autoplay, paste this in between <audio controls>
HTML:
<center>
<iframe width="305px" height="38px" frameBorder="0" scrolling="no" src="http://api.broadcastify.com/embed/player/?key=API-KEY&feedId=FEED-ID&stats=1&as=0&bg=FFFFFF&fg=000000">Your browser does not support iFrames.</iframe>
<audio controls>
<source src="YOUR FEED URL (SOURCE SRC) GOES HERE" type="audio/mpeg">
Your browser does not support the audio tag.
</audio>
</center>
6. ENJOY!
HTML:
autoplay="true"
