Emergency Button on Program
treydawgmt
Carpentersville, IL
Hello all,
Our department has mostly APX 7000, 8000, 7500 & 8500 tri-band radios. We recently purchased an APX7500 dual band radio. I copied over everything into a new codeplug, deleting the UHF frequencies. (Note - I'm using R32.00). No errors. Everything programmed properly. However, it's telling me "Emergency Mode" the instant it is done programming. Any thoughts?
There is no antenna attached at the moment, and there is no microphone attached, but I wouldn't think any of these would matter?
Thanks,
Matt
davidgcet
the emergency switch is programmed but does not have a loop in the accy plug nor an emergency foot switch connected. you have to ground the emergency pin. pins 14 and 15 jump together.
treydawgmt
Carpentersville, IL
Thanks! I figured it had something to do with this, but I wasn't sure. All of our other radios have wireless headsets, and are dual heads. Those have a plug in the accessory plug that I believe automatically grounds those two pins together. Since this will just be sitting on the dash, and be used only with a hand microphone, is there a better way to do this than just a paper clip type thing? Do they sell an actual part that would screw into the accessory plug?
Thank you!
