Emergency Option ???
shadow_dpl
Dear All ;
I'm using Motorola Trunking Prof. Radio CPS System , and also the DOS Pormpts of MCS2000, MTSX838 ...
I wanna ask about something called AG or EG i'm not sure ..
This Thing seems to be TG for emergency ... Right ?
Please provide me with more details and tell me how to activate or use this .
WayneH
Forums Veteran
Super Moderator
Your master site
You want to setup emergency for a trunked radio? Seriously, see your system admin or do not even touch the feature.
SLWilson
Ohio
Programming !
If it isn't ALREADY programmed with the emergency feature, you probably can't even access anything in the radio. EVERYTHING the radio does is something that has to be programmed through the software.
Each button can be setup to do whatever you want them to do, but, as it says above, your SYSTEM ADMINISTRATOR better program it!!!!
Steve/KB8FAR
shadow_dpl
This feature is already disabled in the software ... i would like to know how to activate it ,,, could this be done by changing something in the syskey itself ?!! i don have the idea !!
see the attached photo plz
rescue161
KE4FHH
Hubert, NC
Seriously, if you don't know what you are doing, you need to erase the CPS from your computer and sell the radio.
Why do want to enable the emergency feature anyway?
If you have a legit use for it, then do as stated above and take it to the System Administrator and have them enable it. This is one of the many features that can bring a system to its knees if it is programmed into a radio wrong, so PLEASE have the System Admin or their staff do it for you.
