Enabled Hit Counts
lsmith456z
Hi, GRE psr 500 using prsedit.... I've enabled "hit counts" to determing which conventional/trunk object get the most hits. My question is that I'm not seeing any change in the hit counts for trunking objects. I noticed that there is some traffic for TRGP's but not allot, hoever my hit counts for these groups never register and remain at zero.
1) Is there a reason why the hit count doesnt change for trunjking objuects?
2) Are these trunk groups normally this quiet? I have several configured that were downloaded directly from RR.
thanks in advance
Swipesy
Northern Ohio
Hit Counts are not a per System or per frequency option. It is either on or off for the entire scanner. So if you are not getting TalkGroup hits but conventional hits then I would say you are not receiving transmissions on the TalkGroups.
