Enabling a Custom Scan List - XG-100P
wesky
G'day,
I have setup a custom scan list. I have no idea how to select it and then enable it in the radio.
In Menu > Scan > STAR SCAN: The option is greyed out and it's not my customer scan list that shows.
In Menu > Scan > SCAN LIST > CUSTOM LISTS: I can see my custom scan list at the bottom (there's a total of 3 in the list)
How in the world do I turn on scanning for my custom scan list?
If I start scanning, it seems to only scan the top-most Group Set, as seen in my SYSTEM LIST.
Surely I'm missing something really simple here.
I have also mapped the encryption toggle (under the volume kmob) to 'scan on/off'. When I twist it to the left, it's scanning the north of Group Set in my System List.
Thanks in advance!
BMDaug
I am licensed…
Central Colorado, USA
You need to set the scan list for the system in settings. If you don’t select anything, it will default to scanning the system as defined by the set. If you assign the custom list to a trunked system, it will scan conventional and trunked entries. If you assign it to a conventional system, trunked entries will be omitted.
-B
northstarfire0693
North Carolina
-B
On a trunked system, I have only seen that work on Enhanced CC. If you have it set to Fixed or Dyn pro scan the scan list setting is grayed out.
