I've been working with end-fed "random" wires as quick and easy antennas for transmit and receive while traveling. I'm seeing some conflicting information about critical design parameters. Lots of talk about the lengths of the wire to avoid on the various bands, but not much about feed-line length. As I understand it, the outer surface of the shield on the feed-line coax serves as a counterpoise. So what is the design issue? I've heard everything from "as long as you can make it" to "at least 25 feet" to "it doesn't matter, just make sure to use a proper choke to avoid common mode". Any thoughts or observations from folks about the proper setup for a quick end-fed wire antenna?
