Enhanced ID vs MDC1200
gatekeep
FAIL 01/93
New York, NY
MDC1200 is exactly that MDC1200.
Enhanced ID is essentially the Harris equivalent of Motorola TPS (Tactical Public Safety); which is essentially just a P25 data packet containing the 7 digit P25 LID. I can confirm that the Harris Enhanced ID and Motorola TPS are cross-platform (e.g. the Harris decodes the P25 PTT ID packet from Motorola, and the Motorola decodes the P25 PTT ID packet from Harris) compatible.
IFRIED91
Arrive alive
NYC/Westchester/around the area
I’ve been told the FDNY dual chirps u hear on Fireground frequencies is just this right? But then Motorola has a plugin called G587 FDNY TX/RX tone set which work in conjunction with TPS
GTR8000
NY/NJ Database Guy
BEE00
G857-FDNY Emergency Rx/Tx Tone Set has nothing to do with TPS. G857 is a FLASHcode option (not a "plugin") that allows the radios to generate a specific set of emergency tones.
IFRIED91
Arrive alive
Yeah I’m just learning the ins and outs of Motorola… so those tones u hear at an incident on FDNY Tac channels is that tone set?
GTR8000
NY/NJ Database Guy
BEE00
I don't know what tones you're referring to. Could be the TPS you're hearing, could be SCBA PASS alarm, could be G857. 🤷‍♂️
gatekeep
FAIL 01/93
New York, NY
Yes, I believe what your hearing is TPS (e.g. P25 PTT ID on Analog channels) on FDNYs tactical channels.
rjschilder
AES FTW
Let me test it out on my XG100P… I have feature 57 enabled… oh another question… what’s DES-CFB?? Only available on wideband tho
DES-CFB is for DES encryption of analog channels. XG-100 and XL-200 support it for sure.
IFRIED91
Arrive alive
I Just programmed a simplex radio to radio channel and enabled enhanced ID... the other unit just hears nasty beep more like a screech in place of MDC1200. im guessing this feature is meant to be used in conjunction with compatible fireground accountability systems that decode P25 IDs
