Kingwood, WV
So yeah I’ve been a ham for about ten years but have just recently been getting into SDR stuff… I mainly need a good quality SDR radio for HF stuff, 3mhz-54mhz. I wouldn’t mind to monitor vhf/uhf stuff too.. So should I get a RTL Dongle V4 with a dipole kit to start out? Or should I just get one of the Airspy or SDR Play units? I want to be able to access a decent chunk of scope at a time too. Any recommendations are greatly appreciated. And what kind of antenna? A dipole or a magnetic loop?
N1EXA
FT8 Huntin Mudd Duck on the deep end of the pond !
Acushnet Heights New Bedford MA - GRID FN41 mp
This is the way I went - The Up converter really helps on the front end of the SDR for HF listening . You need a delta loop or good tuned dipole.
The 125 mhz hf Up converter works great on a Standard Police scanner if you want to listen to WRMI or some other Station with Dedication.
Im running HDSDR with the Correct DLL File and USB drivers on Multiple computers with no problems.
I ran A USB extender cable to get the SDR far away from the computers and closer to the outside antenna - It gets you far
away from any Shack noises like PCs and Lights that generate noise.
Pete N1EXA
N1EXA
I believe it just like ham and dmr I see guys using do fkes 5-7 years no issues
Once you figure out how to make it work with the correct Files you can find SDR software that you enjoy using.
I like HDSRD but other Members here may no like it or have another favorites.
The Noo Smart SDR gets warm but I mounted mine to A heat sink and its fine.
The Thing is sweet to really Home in on CW signals and SSB but the antenna is the Secret Sauce. Too Many Newbies
run a wire not thinking of the frequency and Line Impedance and expecting top results or using the supplied antenna which
is more of a box filler.
Enjoy
Pete N1EXA
Kingwood, WV
Enjoy
Pete N1EXA
So stay away from the dongles?
N1EXA
The dongle Is fine there are many out there I just like the Noo stuff because its compatable with Software you will see lots on ebay and there
all got thier CCR Issues.
I think just sticking it into you laptop USB port and letting it hang there is a bad idea because it stresses out the plug and you are next to
a noise generator (PC) so I run an USB extention and have the SDR out at the HF antenna feed Point.
I find the SDR dongle direct to the HF antenna to have many issues because it lacks decent filtering to I run the HF up converter.
You taking HF and putting it 125 Mhz Up in Frequency where the SDR is pretty efficient and running there - the Upconverter has some good
feed point filtering but i run a AM broadcast band Trap to kill the local 1340 and 1420 KHz AM sites near me. You can run An Fm
Trap if the local Music station get into everything like on the Airband.
You just ad 125 Mhz to the SDR software at the option Section and this software does its job.
Read around There is a learning Curve its not going to run out of the Bubble pack and do majic stuff you need to make it work for you.
Pete N1EXA
N1EXA
Start Small dont spend to much and see if you like it and feel it out.
These things are not going to replace a ham HF radio but there pretty Cool for what they do
I have one as Pan Adaptor on my Galaxy Saturn CB base so I can see what the radio
is looking at .
Here is a simple low Budget Noo Electic - it does recomend the Up Converter for Below 25 MHz in the Discription.
Pete N1EXA
