EREC (Electric Utility) Northwest Florida
JamesBrox
Santa Rosa County, FL
I'm reaching out to see if anybody here in Escambia/Santa Rosa counties has had any luck monitoring Escambia River Electrical Cooperative. I talked to a very nice and informative guy out of Dallas, TX about a month ago (Hiegtx) and he was kind enough to do the research and sent me the breakdown of this UHF DMR system....smart fellow. Two systems were set up EREC MotoTRBO and EREC OFT DMR One Frequency (OFT). The Systems, Depts., Sites and Frequencies, which are now in my Sentinel and in my scanner(s). From what I understand, I should be able to hear something and yes...I have the upgrade keys. But I haven't heard anything. I understand to be listening during storms to get hits but I don't understand if these frequencies are registered in FCC and are not encrypted, why am I not hearing day to day operations. Also requested was to run LCN finder each site. I do that when I can. Any input would be appreciated.
batdude
Florida Db Admin / Florida Forum Moderator
Moderator
East Central, Florida
JamesBrox
interesting. I only see one real license for this Coop -
and that particular license says "for telemetry".
without knowing more of the details that were provided to you on their DMR or OFT.... It will be difficult to help.
it's certainly possible that they are on a business DMR system rather than using their own (?)
doug
Not sure how to share what he sent me.....being it was just him and I messaging each other. Maybe if Steve reads this, and he still has the info. He'll be willing to copy our thread here.
hiegtx
Dallas, TX
doug
doug,
When James & I first started kicking this system around, I saw the same license you linked, undoubtedly for telemetry, not voice.
But there is another license for the utility:
What, of course, I would not know is whether it is in active use. I'm well over a thousand miles out of range. What I provided to James was a pdf file with step by step instructions & screenshots on creating a trunked system based on the license. I also (in our conversation) included settings to make One Frequency Trunked systems using the frequencies. The main purpose of initially using OFT systems instead of a normal DMR trunk is that it gives you a better opportunity to see if there is any activity on the frequencies, as well as a starting point for color codes used on each site, and a sampling of talkgroups.
It's possible that the utility is not currently using the system, or only would use it during 'disaster' operations, when there is a maximum effort repair operation is occurring do to damage from, say, a major hurricane. If the utility has migrated to using MDTs or PTT via the cell network, then the prospective DMR system would not be in use. Here in my area, the local gas utility is using MDTs & PTT cell instead of voice communications that a scanner can monitor. Oncor, the power distribution entity that covers a large part of the state of Texas, has an older EDACS system, but is migrating to P25. But even with such a large coverage area, there's surprisingly little radio traffic, except after a major power outage event due to storms.
batdude
Moderator
thanks for the reply @hiegtx -- what I recommend is plugging in the following and see if anything (including DMR data burps) are keying up:
460.6875
460.7125
460.8125
461.6625
461.95
461.9875
462.0375
463.200
463.225
463.3625
463.9375
464.300
464.35
464.3875
from what I can tell, this is a fairly small operation - probably not a lot of radio traffic. (just my guess)
doug
hiegtx
Dallas, TX
460.6875
460.7125
460.8125
461.6625
461.95
461.9875
462.0375
463.200
463.225
463.3625
463.9375
464.300
464.35
464.3875
doug
Attached is a zip file containg EREC programmed both as a full trunked system, as well as an OFT system with each frequency set as an individual site. This was also in my original conversation with James back in June.
  • EREC 2.zip
JamesBrox
460.6875
460.7125
460.8125
461.6625
461.95
461.9875
462.0375
463.200
463.225
463.3625
463.9375
464.300
464.35
464.3875
doug
EREC is owned by a parent company named Touchstone Energy Cooperative. Touchstone owns a lot of rural electric coops in NW Florida and south Alabama. Baldwin County EMC, Chelco in Walton county, and Gulf Coast Electric Coop in Bay county, just to name a few. Maybe this will help in more research.
