I bought 2 new SD cards that were supposed to be pre-programmed
I've tried preparing them on the whistler software but it just comes up error 05 when I try them
all updates on the scanner are current too.
Could you go into updates & see what firmware you have.
Seem to remember,older firmware & get an error. Tell us more.
What are you trying to do when you say that you are preparing them on the Whistler software?
Will that mean that you have a computer to access the scanner using USB and you can take a look in the SD cards, when the scanner are in its Off state, if there are actually some files on it?
The user manual says this:
05-00 Unable to load CONFIG_.BIN Reformat the SD card using the PC Application "Prepare SD Card for use" option. Replace the SD card if the problem persists.
05-01 CONFIG_.BIN file error Reformat the SD card using the PC Application "Prepare SD Card for use" option. Replace the SD card if the problem persists.
05-02 CONFIG_.BIN file error Reformat the SD card using the PC Application "Prepare SD Card for use" option. Replace the SD card if the problem persists.
05-03 CONFIG_.BIN file error Reformat the SD card using the PC Application "Prepare SD Card for use" option. Replace the SD card if the problem persists
So it could then be some sort of mismatch in the firmware versions as suggested. Maybe the SD cards where done for TRX1 instead of TRX2 or a mismatch between the USA version and the E version of software and firmware, or the SD cards are blank as it cannot find the first file it is supposed to read at boot. Do you have the E firmware installed in the scanner?
/Ubbe
